Not a Valid Month
I have created a webi report with a date prompt. When i am running the report, it is giving the following error
“ORA-01843: not a valid month (WIS 10901)”
The datatype of the date object is Timestamp (6) in the database and the object is getting parsed in the universe. The format is dd/mm/yyyy and i am entering the prompt values in the same format.
Can anyone help please??
sabitha (BOB member since 2010-02-18)
Default date format is MM/DD/YYYY .
Try with giving inputs in MM/DD/YYYY format.
pravin_gaikwad :india: (BOB member since 2010-03-27)
Thanks for the reply. I am entering 01/01/2012 still i am getting error.
Please try format ‘YYYY-MM-DD hh:mm:ss’ and let me know its working or not…
Check the LOVs generated at the universe level…it would be easier for you to check the format.
nitin_gons :india: (BOB member since 2009-05-26)
Removed as per this topic.
gigi (BOB member since 2010-03-27)
