Not a valid logon token. (FWB 00003)
Below is Error Message: :hb:
Could not save the document to the repository for the following reason: [repo_proxy 30] DocumentFacade::uploadBlob - Query execute has failed : Error occurred while attempting to reconnect to CMS : Not a valid logon token. (FWB 00003)
(hr=#0x80042a70) (WIS 30567)
We are getting this error after installing Fixpack 2.8. Let me know is there any workaround to resolve the issue.
Puchu (BOB member since 2009-11-16)
Which version of BO are you using?
nicholas (BOB member since 2008-07-31)
I’m getting the same error. I’m on BOBJ Enterprise 3.1 SP3.
I either have to restart the WebI services or reboot the server to fix. It’s happening with scheduled webi reports about once a week.
phaak :us: (BOB member since 2006-06-08)
We’re experiencing the same and it’s a known bug: see ADAPT01374806
According to SAP Note: 1432731 - Scheduled to be fixed in SP4?
This was posted by SAP on 15/09/2010 so I assume they’re not referring to 2.4 but then the question is what as far as I know 2.9 is the last release and everyone is waiting for XI 4.0 so :roll_eyes:
They basically suggest that you restart the webi servers until then, but I’ve been doing that for months and now had an instance where I did exactly that and left for the day (weekend) and all subsequent jobs failed again :reallymad:
Do you restart the Web I Processing Servers or the Job Servers?
joefonseca79 (BOB member since 2007-07-03)
The sap notice refers to WEBI Report servers so I restart them both.
SAP Note 1698491 mentions that this known issue will be resolved in XI 3.1 SP 5. But you mention that it will be corrected in XI 3.1 SP 4.
http://scn.sap.com/thread/1698491
Which Service Pack will this known issue be resolved in?
adagetz :us: (BOB member since 2005-10-20)
We have been seeing this on the BI 4.0 Sp2 Patch 19. Have any one have come across the similar issue and what was the resolution for this. ? This happening while saving the report / Scheduling the report.
Error
Siva.M
looksmee :uk: (BOB member since 2006-02-08)
Same Version same issue here as well. It seems that SAP is trying to fix only the connectivity with its Ecosystem no love for the main functionality :frowning:
jkanaks :greece: (BOB member since 2005-06-08)
