No Join Condition in Auto Documentations
I am using BODS Designer 14.0.3.273 and repository 14.0.0. I inform customer that BODS is able to generate report from the Batch job to be PDF and MS word but unfortunately there is no JOIN Condition showing on document. So does BODS team planning to have it or any other idea about this?
thanach (BOB member since 2011-07-12)
Has to be a bug. Can you talk to support?
Hello Werner Daehn,
I talked to Support, the support saids “Since now auto documentation is by design, if you want a new feature
to be added, you could submit an enhancement Request in Idea Place.
Please refer to kb 1515837 on what is Idea Place and how to submit an
enhancement Request.”
So, No Join condition in Auto Doc seems not be the bug.
Kindly share your knowledge.
I think you will see the mappings and where clause when you click on the Query transform
can you give me the incident # ?
I don’t think this is by design, from 4.0 onwards, you can define the join condition in From tab and filter in WHERE tab, the auto doc should display both, join condition and where when you select the Query tansform
this looks like a bug to me
Hi manoj,
here is the incident ID 90186 / 2013
