no data to fetch
hi,
I have a prompt of country and state if I choose a state if there is no data in state it should not display no data to fetch it should come some thing else I have seen some where here only but I could not find it pls any body help me out these but with out using macro there is a simple way to do that I did earlier but now I am not getting …
cheers! :roll_eyes:
srinivasdq :uk: (BOB member since 2006-11-22)
Before you post search the forum… this is the most frequently asked and answered issue.
Check the FAQ’s first… here is a link from the same
https://bobj-board.org/t/15226/19
First remove Prompts from query panel and run it if it is retrieving data, for that prompts combination no data in ur database.
shekarbob :india: (BOB member since 2007-07-20)
