hi all,
i have a deski report.which i am creating using free habd sql.now when i test my sql in toad and teradata it gives me the output but ,when i use the same in BO it gives me message that no data to fetch.so what’s the issue?
can anyone help?
The problem might be the input which you gave in the wrong format or wrong value.IF it is a date then give a existing value/format by checking in database.
