new SIA using oracle db not seen after wizard finishes
xi 3.1 sp3
I have a vm environment where teh curent enterprise had different server name than what they are now. I am not trying to configure the environment to use the new server names.
I thought the easiet way would be to create a new sia using the old oracle cms/auditing db.
i have stopped the existing sia and run through the wizard to create a new sia. the wizard completes without errors and then shows the loading box. that progress bar doesnt do anything and then eventually goes away without showing any new sia.
maybe i am entering the wrong info into the wizard?
i saw a couple of other articles where users were asking about this same issue however there was not a resolution. would sp4 fix this problem?
should i just manually change the folder names and file to the new names? that kind of seems like a pain…
any ideas?
giggles7840 (BOB member since 2007-07-13)
