“Rosen, Barbara” wrote:
We are currently using CAE 2.1.2 and DDCS in production with BO4.1.1. We are
trying to get CAE 5.1 to work with v4.1.3 or 4.1.4, but haven’t been able to
successfully connect yet. We get an invalid cursor position error on an SQL
GetData and then the time reference message. Tech Support claims that the
v4.1.4 should work with the new CAE but cannot explain why we are having
this problem or how to fix it.
Did you also check the “advanced settings” in the universe connection dialog?
Set the array fetch size to 1, sometimes this helps.
hope this helps.
Walter
DI Walter Muellner
Delphi Software GmbH, Vivenotgasse 48, A-1120 Vienna / Austria
Tel: +43-1-8151456, Fax: +43-1-8151456-21
e-mail: w.muellner@delphi.at, WEB: http://www.delphi.at
