You can create your cross tab using sample database that comes with CR XI. Use the customer table in the report and follow the following steps:
1.Go to Insert menu>> Cross Tab.
2.Place it in Report Header.
3.Select it and right click>>Cross Tab Expert.
4.Now select the Country filed and press > button beside rows.
5.Select Sales column and click > beside Summarized Field.
6.Click ok.
7.Preview the cross tab.
8.You will see country names and sales data.
9.Now goto page no 1 of the report.
10.Select the country field.Right click>> Format Field.
11.Click Common Tab.
12.Click the X^2 opposite to display string.
13.A formula workshop will appear.
14.write this code:
global NumberVar x;
x:= x+1;
totext(x,0) + " " + (CurrentFieldValue);
15.Click OK.
16.Preview the report.
17.You will be able to see row numbers along with country names.
Top X customers
1.Create a parameter of number type and name it Top N
2.Select the Cross Tab. Right Click>>Group Sort Expert.
3.Select Top N.
4.Select Sum of Customer Sales in the based on drop down.
5.Put 1 in the Where N is
6.Click X^2 and select the parameter created Top N.
7.Uncheck Include Others, with the name.
8.Click Ok.
9.Enter the value of parameter prompted.
10.Preview the report.
Let me know if you have any questions regarding this.
