BusinessObjects Board
Need to document parsing of objects in Universe
I have 7000 objects in universe and now the database has been restructured and now I parsed the objects by checking the integrity option.
So now is there a way to document all these as I have only one option there to print which is saving as prn file in an unreadable format.
Please let me know if there is an easy way to check the non parsed objects rather than parsing each and every object.
Thank you.
BOXIR3.
Vamsi
vamsi krishna (BOB member since 2005-11-18)
Install PrimoPDF and print to that instead. It will produce a PDF file for you.
I tried installing Primo PDF and tried to save to file into Primopdf format but still ADOBE says it cant open the file…
You’re meant to print - PrimoPDF acts as a printer, not a file format. :shock:
Another option is cutepdf - either way, you use them as a substitute for the printer and open the pdf as you would do any other pdf document.
you can get this info with SDK. See this topic for using the excellent universe documentator - i’m not sure if latest version outputs integrity check results but i don’t think it would be too difficult to include.
I think I have code somewhere and can post if required
rgds
AL
agulland :uk: (BOB member since 2004-03-17)
