Need logic
Hi ,
I have 35 source systems on MS SQL Server. Source system/database connection details are different. From each source system/database I have to extract the 35 tables . Table structures are same from one database tables to another database tables. I have to load these tables into single target target database. In my scenario I will have 35 target tables . In the target table I have extra field name is source . I need to give the some source database details in the extra field like USA ,UK etc .
DB1 A T A
DB1 B T B
DB2 A T A
DB2 B T B
DB3 A T A
DB3 B T B
I want to schedule my jobs to load the data.
  1. I cannot use the data store configurations as I am using scheduling and I cannot change manually data store configuration option or system configuration option .
Do I need to develop the jobs for the one source database and replicate the jobs and changing the source tables from another data store ?
How can we reduce the job development effort without replicating the job and changing the source tables for remaining 34 databases?
Please help me in this .
Thanks & Regards,
Ramana.
Ramana :india: (BOB member since 2009-04-30)
Use a while loop to capture the table names in a variable. Pass the variable names to a parameter and use SQL transform to call the parameter and load one by one to the target table.
Arun.K :us: (BOB member since 2011-10-18)
You need to use System Configurations. This is exactly what it was designed for.
I am not quite sure if the SQL tranform logic would work as the Datastores need to be changed.
One solution that might work is :
Create jobs/Dataflows from Files to Target database. Files would have the same structure as hose 35 tables.
Run time , in DS script , use SQL bulk export to export table data to a file.In DS script you can change the connection value using variable.
now same job/dataflow can be used for multiple source systems with connection name.
Worth a try.
basy2005 (BOB member since 2013-02-13)
