Need list of reports with associated Uni from CMS repository
I need to collect list of reports in our system and associated universes if possible.
Is there any limit on number of rows return by query in AdminTool.
When i used below query, i am getting only 1000 rows
Select SI_NAME from ci_infoobjects where si_kind in (‘Webi’)
But when i query for count, i am getting around 7500
Select Count(SI_ID) from ci_infoobjects where si_kind in (‘Webi’)
Does any body have any idea? Any solution for collecting metadata about repository?
Any help would be greatly appreciated.
MightyBO :us: (BOB member since 2007-06-28)
This Excel utility with several lists from the downloads section is a more suitable option.
Also: SELECT top 64000 etc for the query tool
… but be careful as to the size as you can wait ages for everything and then trying to screenscrape this into excel etc causes page hangs - so use ranges or filter the result set.
