system
March 23, 2010, 6:55am
1
HI All,
I am new to Xcelsius. Just need information what are the data sources we can connect through xcelsuis? how to conncet?
Can we connect MYSQL database through Xcelsuis?
Can we connect MS Access database?
Can we connect oracle databse?
Please let me know how to connect above sources. or you can provide me any documents.
Venkat
venkata_somisetty (BOB member since 2009-08-12)
system
March 23, 2010, 7:00am
2
Data sources supported in Xcelcius2008 Enteprise are
BusinessObjects universes via Query As a Web Service, SAP BusinessObjects Web Intelligence and Crystal Reports via SAP BusinessObjects Live Office, Microsoft Excel 2003/2007, XML compliant databases, Microsoft SQL Server Reporting Services 2003, SOAP-based Web services, Adobe LiveCycle Data Services, Flash Variables
Bilahari
billu (BOB member since 2009-11-09)
system
March 23, 2010, 7:04am
3
Thnk u Billu for your reply.
But i need information for my question.
Can we reach my requirement through xcelsius?
Venkat
system
March 23, 2010, 9:33am
4
Hi venkata_somisetty,
Please check following thread on this…
xcelsius connectivity with mssql database
Bilahari
system
March 23, 2010, 1:06pm
5
Yes, you can connect indirectly to all of those.
Various methods:
via a Bob universe & QAAWS/liveoffice
via flynet or similar
via aspx or similar scripts that directly query database and return xml
These have all been discussed in this forum at great length. Just search and/or buy an xcelsius manual. That’s the way I learned.
debbie
Debbie (BOB member since 2005-03-01)
system
March 23, 2010, 10:47pm
6
You can connect to any kind of data, however you either have to use a developed web service or model your database in a business objects universe.
Here is an example of calling a web service in Xcelsius. This is a simple example, you just need to access your database instead.
http://www.xcelsiusinfo.com/2010/03/03/beginners-guide-to-xcelsius-part-4/
ericvitale (BOB member since 2010-02-23)
system
March 29, 2010, 9:02am
7
Hello Venkat,
Using Flynet Web service generator you can connect to all of the above databases provided you have the Oledb or ODBC drivers installed on the machine where the Web service is to be hosted.
If you need further information you can contact us for a trial of the software.
Best Regards,
Ian Learmonth
ianlearmonth (BOB member since 2008-10-22)
system
April 1, 2010, 12:18pm
8
Thanks to all for given indeed useful information.
Venkat
