I have BO XI installed on server by my admin. Iam unable to find the default web-path for accesing OLAP11. Also looking for some PDF documents on using OLAP11 and its features.
I would really appreciate for any info provided on OLAP 11
This is BO XI R1
Have you done the OLAP Installation after you installed BO XI?
According to my Knowledge BO provides a differnt CD for OLAP and that needs to installed once your BO XI installation is completed.
And this is a key distinction. In R1, you do have to perform a separate installation on the server for OLAP Intelligence. The installation prompts you for desktop vs. web installation. In R2 however, the separate installation is not necessary. Everything needed on the server side for OLAP Intelligence is included in the BOE installation.
