Need help with Prompt to run for all the companies.
Hello,
I need to create a condition in the universe which will allow them to run the report for all companies or only to the companies that they entered during Prompt.
Here is the one that i am using for only 1 company. How to convert this to run for all the companies or for the multiple companies that the user wants to run.
@Select(Financial Management\Company Number) = @Prompt(‘Enter Company Number’,‘n’,‘Financial Management\Company Number’,mono,free)
Raju
Rajua99 :india: (BOB member since 2004-12-16)
Hi ,
Just change the Option Mono in your @ Prompt condition to Multi .
Hope this helps
Sapan
swapnil_taz :india: (BOB member since 2006-04-06)
It will not work with the “=” (equal sign) in the condition.
Either construct this as an optional prompt (Webi) or define this as:
@Select(Financial Management\Company Number) in @Prompt(‘Enter Company Number’,‘n’,‘Financial Management\Company Number’,multi,free)
tbunnik :netherlands: (BOB member since 2005-06-08)
Thanks, This is working. is there a way to make this prompt to run for all the companies when they enter 0 or not instead of selecting or entering all the companies in the prompt.
Check out the Designer FAQ
Yes you can.
@Select(Financial Management\Company Number) in @Prompt(‘Enter Company Number or 0 for all companies’,‘n’,‘Financial Management\Company Number’,multi,free) or 0 in @Prompt(‘Enter Company Number or 0 for all companies’,‘n’,‘Financial Management\Company Number’,multi,free)
