Need Help to see live Office in Xcelsius
I have Installed Xcelsius 2008 and Live office in my system but i could not see any connection at Add connection option.Do i need to integrate with live office with Xcelsius?
Would you please help me out.
Pooja
ktm :us: (BOB member since 2008-11-12)
You will do that in excel. I believe Live Office is to connect to the BOE repo and pull a report. Check your excel and see if you can see any Live Office stuff.
P34C3 :us: (BOB member since 2005-11-30)
siru, did you get this resolved? If so, what specifically did you do to get the connections to show up?
kmspsu93 :us: (BOB member since 2006-04-06)
Can you Please Tell me what to do in Excel?I used live office to get the Objects from the Universe.
I am still facing the same Problem.
Pooja
I am interested in this as well. We have created the Live Office doc and it refreshes fine against a simple e_fashion webi report part. Import the doc into Xcelsius, and then manage connections, select Live Office Connections and then a blank screen.
Your problem may (?) be related to the following post…
kjb :us: (BOB member since 2008-06-04)
