Need help to create object using dual
Please help me with the select statement in an object.
Select (Select count(Table_name.column_name) from ready_queue) + (Select count((Table_name.column_name)) from working_queue) from dual.
Thanks & Regards,
JAASI (BOB member since 2004-06-08)
What are you trying to accomplish? Why are you trying to involve the DUAL table?
Thats the select statement to be used for an object in the universe. Its an existing field in a HTML report that is being converted to BO reports.
Maybe it’s a guide as to what you should be doing in terms of your universe design – but I don’t think you should expect to use the statement as-is. What is it supposed to be doing?
Thanks. I was thinking these were some advanced queuing techniques in Oracle, but found out that these are tables. I am done with this now.
