Need extra row at total with wide column for Remark
Hello. I am trying to create a 2-line total at the report break. The first line of total (which is fine) is to print to Total amounts. The second line is to print a remark that relates to the break. I am trying to make the second total line have one big wide column for the remark which is different than the detail and first total line. Every time I try and change a cell in the second total line, the entire column changes widths! In Deski, you could change the width of one cell in a total row without impacting the entire column of the report. Is this possible in Webi XIr3? (Sections are not desired in this particular report).
Thank you for any help. Here is a brief example:
PO# Line# PO Qty etc etc
1 1 25
1 2 10
Total PO 1 35
PO 1 big long remark to print like this
2 1 15 etc
AHarper (BOB member since 2003-01-24)
Have you tried merging the cells? That should give you more space. After merging you can change the properties to autofit height and wrap text or autofit width. Hope this helps.
SST :us: (BOB member since 2008-03-25)
