system
#1
Hello BOb’s,
I have an URL below to read the data and extract.
https://api.squishlist.com/rest/?method=squish.project.search&cfg=keenan&token=31d11805af4318b1ed3570226c26a1456f14aed4&prj=cbms&24567=169645
Can you please give assistance on this for which type of Adapter should use or any other way/configuration ???
Appreciate your help!!
vasanthasuresh (BOB member since 2011-07-28)
system
#2
if you are on DS 4.2, then use Webservice REST datastore, no need of Adapter
if you are on pre 4.2 version, and the output of this URL is in XML format, then you can try using HTTP Adapter
system
#3
Thank you manoj.
We have DS 4.2 SP03. I have created Webservice REST data store and it is expecting the .wadl file.
But I have the URL which will returns in JSON format…
How Can I convert the JSON into .WADL or should I need to do any other way to extract.
system
#4
you can use SoapUI to generate a WADL file using the URL that you have
