I have a prompt at the universe level and the field is a number field. Now I need to implement the logic wherein if users selects 1 , all accounts should be displayed, it is similar to All option but as this is a number, there is some issue which I am not able to understand, could someone please guide me ?
Thanks for your prompt response on this. The below is a code I am trying to use-
(@Select(V Id Party By User\Id Acct Seq) in @Prompt('SQACCOUNT','A',,multi,free) OR ( '1' in @Prompt('SQACCOUNT,'A',,multi,free)))
And it is giving error - Invalid Defination. Error parsing first parameter.
Edit: Hi Marek, the below one is working but I have not still tested it-
(@Select(V Id Party By User\Id Acct Seq) in @Prompt('SQACCOUNT','A',,multi,free) OR ('1' in @Prompt('SQACCOUNT','A',,multi,free)))
But I have a confusion here, shall I do it by creating a new object like generally we do for " All" or this is fine if I go ahead with this solution? Kindly guide me…
You mentioned that it’s a prompt for a number field. However, the above code is for a prompt for a string field - you use ‘A’ as the 2nd parameter of the @prompt() function, as well as ‘1’ as the “ALL” value.
