Hi Freinds,
need a help to make requirement given below in bods
i have column value given below
abc-meer-abcd
abv-meer-abc-123
so i want only output like meer only
Basha
meer.9700 (BOB member since 2017-12-27)
Hi Freinds,
abc-meer-abcd
abv-meer-abc-123
Basha
Is MEER always between ‘-’ and ‘-’. If so, you could use a multi-step process. In you first query transform use the substr and index functions to strip away everything up to and including the first ‘-’. In your second query transform use the same functions to get all data before the second ‘-’.
Nemesis
(BOB member since 2004-06-09)
The Data Services function word_ext() can easily pick a value out of string when you are looking for a specific position.
eganjp
(BOB member since 2007-09-12)
