Namespaces in XSDs
I know that version 11.7 will fix some major issues with namespaces, like allowing you to select them when defining the XSD etc but is there a way around an issues I have.
I have an XSD that contains a namespace, when a document is created against this namespace all elements are preceded by ns1:, is there some flag I can use to switch this off?
e.g. I get
ns1:Header/
Rather than
jardinsa :australia: (BOB member since 2006-10-26)
Could you please let me know if you have got the fix for this issue?
niranjan479 :india: (BOB member since 2014-01-08)
Any solution to this issue?
boe_bods :india: (BOB member since 2008-03-14)
Hi ,
I am also facing the similar issue. My XSD has 2 name spaces and when I have generated XML using BODS , it is adding the alias as NS1 & NS2 in XML tags . Is there a way to remove these name space alias from the XML.
Sai
tangudusaikumar (BOB member since 2009-12-14)
