I created a match review configuration and generated a task to be reviewed. I assigned it to all user groups for review.
so the log shows Tasks is created successfully and i am able to see the task in lower portion of configuration manager also.
When i close the window and try to see the same task in My worklist , i dont see it there. My worklist is completely empty and not a single task is visible.
At database level , the status of job is changes to in progress.
Any idea why the tak is not visible in My worklist but available in bottom portion of configuration manager.
I checked all filters and eveything and nothing seems to be wrong.
in CMC , when i open properties of the Task , it throws a Java Error.
It appears the logged in user is not a reviewer or approver in the match review configuration or is not part of the reviewer or approver group. The Match review task will show up in the worklist for the user(s) who are defined as the reviewer or approver in the match review configuration. You can also verify the worklist task actually exist by uncheck the “Show only my worklist” checkbox at the top, it will show you all the tasks even if it’s not assigned to the logged in user.
