My Business Object Thick Client MENU headers disappeared
I was using BO Thick client and after it was hang once i had to restart it and after restarting it the MENU headers have disappeared can any one suggest me how to get them back i also uninstalled and reinstalled them but the problem still exists.
sumeet_sp :india: (BOB member since 2006-08-01)
See this related post to get you started.
Did you clean out the Windows Registry (reminder: always make a back-up) before the re-install?
I didnt mean Slice and dice panel what i mean is the MENU headers like FILE,EDIT,VIEW,ANALYSIS etc the main menu items have disappeared and are not coming back even after reinstallation
So did you clean out the Windows Registry?
No i didnt because i logged in using other username and the problem still persists
Well I would give it a try, de-installing Business Objects and cleaning out the Windows registry.
Sumeet,
Here You can do,
start–>Programs–>run–>regedit
Registry will open.
go to
HKEY_CURRENT_USER/Software/Business Objects/Suite 11.5/default/BusinessObjects/ApplicationPreferences/BusinessReporter/desktopIntelligence/
Delete all the entries and relauch the Desktop Intelligence.
I hope this will solve your problem.
Steve.
stevent (BOB member since 2005-11-22)
I am not sure which version you are using
check this post:
Nitin
nitin10 (BOB member since 2006-07-10)
