system
October 16, 2009, 6:37am
1
I am having three column
Seq Break : number applied break on it.
Head : dimension this is for Heading
Range : dimension which is giving Multivalue error.
Seq break Head
o abc
DEF
#MULTIVALUE (tHIS FOOTER OF BREAK)
oUTPUT REQUIRED
Seq break Head
o abc
DEF
a.xxxx
b.yyyy
c.zzzz
a.xxx,b.yyy,c.zzz is a Range column
abc,DEF is a Head column
0 is a Seq Break
Kindly help.
Gunjesh
gunjesh (BOB member since 2008-09-15)
system
October 16, 2009, 6:50am
2
use MAX() function in the footer.
Rakesh_K (BOB member since 2007-12-11)
system
October 16, 2009, 6:55am
3
Thanks for reply but I want to use all the value not Max Range.
Gunjesh
system
October 16, 2009, 7:25am
4
go to the properties of the table, there is a property named something called aggregate or aggregation, chk that and try, or vice versa.
Hope it will work.
Zeenat (BOB member since 2007-12-11)
system
October 16, 2009, 7:34am
5
Can you provide screenshot of your report, and screen shot of report in excel what you looking for. That will give us in understabding your requirement properly.
system
October 19, 2009, 5:38pm
6
By all of the values, do you mean a sum?
bkaporch (BOB member since 2008-12-02)
