Multivalue error
I have the following issue and need help ASAP…please…
ID Amnt CD
1 100 A
1 100 B
2 200 A
2 200 B
In the report when a variable is use
If CD <> “D” then sum (amnt)
I am getting a multivalue error. I know i am using there are 2 amounts for 2 different CD thats why? how can i fix this multivalue error. PLease help ASAP?
BODEV2011 (BOB member since 2010-12-28)
Can you give a try like this.
=Sum(If CD <> "D" then [amnt] else 0)
It wont work plus i dont want to sum the two adjustments i want to bring only 100 for ID 1 and 200 for ID 2.
You have codes for A and B and your formula says <> D. That’s going to bring both.
If you want only B, then try a where clause:
=Sum([Amt]) Where ([CD] = "B")
Or the code Jansi provided would work, assuming that you aren’t really looking for everything not equal to D.
Thanks but whatever Jansi provided still doesnt work and am getting the multivalue error. I have said it is not equal to “D” coz i want all the amnts other than “D”.
Also i thought if i can use the Where clause instead of If, but i am getting a context error when i use.
=Sum([Amt]) Where ([CD] <> “D”)
Please let me know.
You can’t use <> in a Where clause, it has to be equal. Try this entry in the Deski FAQ, it will show you how to work around that.
