Hello,
I am getting “#Multivalue” for a character object.
This issue is solved by applying Min/Max for numeric data objects.
But whats the option for charater datatype objects.
Please suggest.
Thanks;
Dipti
MBD (BOB member since 2009-08-18)
Hello,
Please suggest.
Thanks;
Dipti
You can apply Min(), Max() for Character data type too.
Jansi (BOB member since 2008-05-12)
#MULTIVALUE Error occurs when a block is confused when it receives a dimension qulification instead of a measure.
Point where in a block you are receving this error. what is the solution, the local variable and the block where this equation in the block?
KhoushikTTT (BOB member since 2005-02-24)
If I am using Min/Max, the value disappears
If you elaborate your exact requirement, we may help. Also please answer the questions of NewyorkBaasha.
What is the requirement?
Hey The thing is that if im dragging that charater object i should get a value. That object has multipls values and i am trying to get it in a single cell. So its obvious to get #Multivalue in that cell. But we can resolve this by applying Min/Max if its a numeric datatype to get a single value in cell, however the object is of charater datatype. So when i am applying Min/Max, the value disappears. But in formula bar i can see the object present.
Min and Max function would result in the what the object carries which is defined by the function itslelf.
What is the report requirement
I’ve had the exact same problem! I used variables to select the value I wanted but still got #multivalue and when I used min or max, it would disappear (with the formula remaining). I’m going to post a separate topic to see if others have seen a change from XIR2 to XIR3 regarding merged dimensions (which I feel is causing this ), however, my resolution was to break my one query up into 3 separate ones so there would no longer be multiple values for the character description I was needing. I don’t know if that would help you out as well but it might be worth a try…and good luck!
mdower (BOB member since 2009-02-27)
