#Multivalue Error in BO XI3.1
Hi BOB guys,
I’m facing an issue in the report developed in XIR2 and upgraded to XI3.1
I have raw data like this
date format band count
1/1/2009 urban abc 10
1/2/2009 rock abc 15
I want to display the data for the band with latest format as
Band Latestformat count
abc rock 25
In XIR2 we have achived it using formula
Latestformat= max(format) where(date=max(date)) forall (date)
In migrating this to XI 3.1 we are facing a multivalue error
Band Latestformat Count
abc #MULTIVALUE 25
I have tried to recreate the report from scracth but the issue still remains
Wondering if any of the experts could help me.
arbbi (BOB member since 2009-05-19)
Hi, did you resolve this issue? We are seeing something similar here.
FionaCasey :ireland: (BOB member since 2007-01-22)
same here: no problem in XIR2 (although it seems to me that this problem also occurred before XIR2SP2), only in XIR3 !
anybody ?
mirko (BOB member since 2002-08-21)
I had this in two different reports. I was able to fix the issue by putting the ‘where’ bit inside the min brackets, like this for your formula.
Latestformat= max(format where(date=max(date)) forall (date) )
However I have another issue as well as that one.
I’m getting an ‘#UNAVAILABLE’ error inside a section. If I remove the section the error goes away. It’s nothing to do with the dimension that we sectioned on because if I include that dimension in the table but remove the section the error goes away.
Are you using sections in your report? Have you seen this error?
hi,
this error always pops up when I use the following formula:
= Max() where ( = value)
I’ll try the bracket solution as soon as I find the opportunity (no access to an XIR3 environment right now). I’ll make sure to post my findings.
thanks for your help, Fiona.
Thanks FionaCasey for the solusion
Changing
= Max(<object1>) where (<object2> = value)
into
= Max(<object1>  where (<object2> = value) )
works perfect :smiley:
[Moderator Edit: Added code formatting - Jansi]
kflorek :poland: (BOB member since 2007-02-10)
