I have database field which contains names (strings “A”, “B”, “C”, etc.) separated by comma (e.g. “A,B”, “A,B,Z”).
In CRXI I’ve created multivalues parameter to selecting these names.
How could I compare field value contains names that I choose by parameter. For exemple when I choose names “C”, “B” and “A” I want to see both of rows: “A,B” and “A,B,Z” and when I choose name “Z” I want to see only row “A,B,Z”.
Can I use wildcard?
When parameter doesn’t allow choosing multiple values then I could use this solution https://bobj-board.org/t/62494 but when parameter is multivalues then it doesn’t work.
TIA
//EDIT
My solution (formula):
Local NumberVar i;
BooleanVar contain := FALSE;
For i := 1 to Count({?Name}) do
if ({table.names} like "*" & {?Name}[i] & "*") then
contain := TRUE;
Exit For
contain
But I wonder is it possible to omit the use of loop statement?
docent (BOB member since 2009-07-21)
