"Multiple SQL statments for each measure" issues?
Hi Bob,
In my universe “Multiple SQL statments for each measure” is enable.
what happen if i disable the “Multiple SQL statments for each measure” this option in universes.It will effect the data.Can any one tll what is main use of this option. :hb:
kumar123 (BOB member since 2007-08-19)
This option will helpful to avoid chasm and fan traps. Please go through the traps concepts.
KlnReddy
jinkaleo :india: (BOB member since 2007-01-25)
If you enable this option it will create seperate SQL query of each measure you try to include in your query.
In some specific scenarios this is used as mentioned in the above post.
Anoop
Anoop Shihoorkar :india: (BOB member since 2007-02-15)
Multiple SQL Statements for Each Measure is applicable only to the measures.If this option is clicked it will force the sql engine to generate SQL queries for each measure that appears in the Query panel.
And basically it is used to solve fan trap and chasm trap problems. For that you need to read manual or search in Universe thread. :slight_smile:
Anoop
As far as I am aware, checking this option does not force separate SQL queries for each measure. It just means that you can have separate SQL queries if you wish.
I have universes with this option checked and have still had to create aliases in order to force a separate SQL query where required.
debbie
Hi Kumar,
when u enable “Multiple SQL statments for each measure” option in the universe, it will create 2 seperate SQL statements in the query if your query has 2 measure objects that are coming from 2 different fact tables.
REACHLP (BOB member since 2008-10-06)
