We have a Data Services 3.2 installation using an Oracle 10g Client to access various databases.
Is it possible to install a second Oracle client on the server (e.g. 11 / 12) and have Data Services use that for select Data Stores? And if so, if you have a Data Store configured to use the Oracle 10 client, how do you reconfigure it to use the new client as a lot of the options are greyed out once it’s initially setup?
You cannot change the middleware on an existing datastore configuration.
In the datastore configuration you can add a new configuration.
There you can select the new middleware and run the jobs with this datastore configuration.
