BusinessObjects Board
Multiple Drill down issue
My co-worker has a dashboard that has multi-level drill down (four levels). He uses dynamic visibility to hide from where he drills down from. An initial drill down works fine. He has a back button which clears the drill down value and thus hides the current screen.
Everything works fine the first time he drills down and backs out. The issue happens when he drills down a second time. For some reason Dashboards is remembering the drill down values, thus the user ends up at the lowest level.
Is there a way to clear the drill down values?
Dashboards SP 5, FP 7
All data supplied by queries.
kevlray :us: (BOB member since 2010-06-23)
Try adding a blank series… and make this as a default in the drill down tab selection…
did you try using No Selection in the Default Selection
rajx72 (BOB member since 2006-08-02)
