I don’t know about famous grin … but I’m glad you find the utility useful.
As far as a “move” functionality, I’m afraid the answer is no. I would have (probably) included that functionality in the utility if it were possible. There is no .Move method, and the .Id property for classes and objects is not only hidden, but read-only.
thanks for the welcome and for the answer, I’m glad to be here
about the object_id/move issue: is there any other API which supports this operation? If the drag and drop works on the GUI then we should find a way to code it somehow
One would think so … but it’s not the case. We’re spoiled by the Microsoft Office applications, where virtually anything done manually can be automated. There are many examples where the BusObj object models simply are not “complete” in the same sense, and this is one of them.
