MouseOver Line chart values
HI
I am using xcelsius 2008… I have to build a dashboard with a line chart…
for example…
I have 2 buttons and one line chart on my dashboard… I click the button and line chart shows the data for that particular button… till now it is fine…
Now the user wants to add dynamic visibility… means… Initially there will be no line chart… on mouseover of the button he wants the chart to be visible… and on mouseout is should be invisible…
I am able to do visibility part by using icon component…but the data in the line chart comes only when i click the button… I want that data to show on line chart on mouse over of Icon component.
Hope i am clear…all i want on mouse over of a componet… the line chart should be visible with the data in it…
thanks
rajx72 (BOB member since 2006-08-02)
Before how was you inserting the data in the chart? Was that using Push button?
Zaif
zaif235 :us: (BOB member since 2010-06-15)
HI
Yes…when the user clicks the button, the data changes in the chart…
But now I want the same thing on mouse over…
Nameesh
Use the source data component to insert the data and use icon to display the chart on mouse over.
Zaif
Thanks… could you please let me know how to use this component in my situation. still confused on how to achieve the mouse over functionality…
You might get some idea by looking at attached xlf.
Zaif
Mouse Over.zip (8.0 KB)
HI Zaif
This is what i want But how can i add more Icons… also can i use something else instead of using 1…
Enclosing my dashboard… Can i use ProdA instead of 1… Also I want the same mouse over on ProdB also.
test1.zip (7.0 KB)
Hi Raj, Yes you can use whatever you want, but in dynamic visibility and in icon source you have to change the values for it. see the modified xlf attached.
Zaif
test1.1.zip (8.0 KB)
Hi Zaif…
I want to see the chart on both the icons… when i ran you xlf… it is working only on the 2nd icon… (prodB)
I have more than 1 icons… and on each icon mouse over a chart is showing with different data…
if you replace 1 with prodA… then, on mouse over of ProdA a chart is shown… and similarly on moveover or ProdB a chart should come…
Hope i am clear…
Thanks…
What you can do is copy the existing chart and paste it on top of 1st chart and change the dynamic visibility value to 1 and for both menu labels unchecked the clear destination when No item selected. Please let me know if it helped.
Zaif
Got that… thanks… it is working now…enclosing the final version…
Thanks…
Cool :+1: . Make sure you hide those labels somewhere under backgrounds.
Zaif
Is it somehow possible though only one chart…just a thought…
as i have 8 - 10 icons…
Yes :D, please see attached xlf.
Zaif
test1.2.zip (8.0 KB)
Finally got it… thanks… hope it works for all of my icons…
thanks again for the help…
