Our DBA asked me to try putting an extra SET statement in before the SQL
that Business Objects generated. The SQL would look something like:
SET PDQPRIORITY LOW;
SELECT stu_wsu_num
FROM informix.student;
I tried editing the SQL that Business Objects generated and I also tried
typing in the SQL in the Freehand SQL section as well. In both places,
Business Objects won’t let me do it. So, I have 2 questions:
Is there a way for me to put this SET statement in on an occasional basis?
Is there a way for me to tell Business Objects to automatically put the
SET statement in on every query?
Any help with this would be appreciated.
Dennis Edgecombe
Washington State University
dennis_edgecombe@wsu.edu
If you look at the contents of the \Informix subfolder of your BO main
folder, you should find a file that has the .SBO extension. After
you opened this file, you should a entry that reads
EmptySPParamList=()
I have not tried this myself so I cold be way off. Nonetheless, If I were
you, I would try to put between the () the SET PDQPRIORITY LOW; your DBA
wants use in your queries.
Let me know. My 2 cents…
Alain.
-----Original Message-----
Behalf Of Dennis Edgecombe
Sent: Thursday, February 11, 1999 11:51 AM
SELECT stu_wsu_num
occasional basis?
Dennis Edgecombe
