More Graph Problems
The bottom axis of the graph shows the date in the reports. The alignment of the date is set to Vertical but it always prints out horizontal. We have tried everything to get it to print out vertical but it keeps printing out horizontal.
Has anyone else had this problem and if so how did you fix it.
Brian C. Mellinger
Walt Disney World
Security Loss Prevention Administration
brian.mellinger@disney.com
Yes, I’ve seen this. For me, it’s meant selecting a different print driver that will allow vertical printing and nothing to do with BO itself.
Julie Neumann
out horizontal.
Brian,
I encountered this problem also. Changing the font solved the problem.
Best regards,
Thierry
Mobistar N.V.
Belgium
Hi Brian,
I know that this is a bug in BO, but I don’t know in which version it is fixed.
The workaround is to change the font to “Arial narrow”. This always worked on our graphs.
Mathias
From: Brian C. Mellinger[SMTP:brian.mellinger@DISNEY.COM]
out horizontal.
Has anyone else had this problem and if so how did you fix it. Thanks,
Brian C. Mellinger
Walt Disney World
Security Loss Prevention Administration brian.mellinger@disney.com
Brian,
I’ve had this problem as well, If you have adobe writer this can get round the problem.
Tony
