more data returned using free hand sql than sql plus
I am calling a stored procedure through free hand sql that is returning 38 rows of data which are incorrect. When I call the stored procedure it returns only 10 rows of data which is correct. Any thoughts would be appreciated.
Thanks!
ipuffer (BOB member since 2002-12-16)
If you attach the script of the stored procedure, we can help you easily.
By the way, the only thing I’m thinking is “Avoid aggregation of duplicate rows”…
Christian Konrads :it: (BOB member since 2004-07-21)
Perhaps the stored procedure uses “union all” instead of “union”, or viceversa…
It depends on how your procedure is written.
Understanding that this is the first time I am attempting to use a stored procedure as a data source in BusObj I will share our script with you. :smiley:
Remember it is working perfect in SQLPlus.
Thanks in advance!
CREATE OR REPLACE PROCEDURE insert_icis_pipeline1
	(pipeline_report_rc  IN OUT icis_ii.curtyp
	,p_column1	 NUMBER	  DEFAULT  0
	,p_value1	 NUMBER	  DEFAULT  0
	,p_column2	 VARCHAR2 DEFAULT '0'
	,p_value2	 VARCHAR2 DEFAULT '0'
	,p_column3	 VARCHAR2 DEFAULT '0'
	,p_value3	 VARCHAR2 DEFAULT '0'
	,p_column4	 VARCHAR2 DEFAULT '0'
	,p_value4	 VARCHAR2 DEFAULT '0'
	,p_date_column	 VARCHAR2 DEFAULT '0'
	,p_date1	 VARCHAR2 DEFAULT '0'
	,p_date2	 VARCHAR2 DEFAULT '0')
AS
	v_stmt		 VARCHAR2(32000);
	v_add_clause	 VARCHAR2(32000) :=' ';
BEGIN
 	IF	p_column1 <> 0
 	THEN
 		v_add_clause := ' AND '||p_column1||' = '||p_value1;
	END IF;
 	IF	p_column2 <> '0'
 	THEN
 		v_add_clause := v_add_clause||CHR(10)||' AND '||p_column2||' = '''||UPPER(p_value2)||'''';
	END IF;
 	IF	p_column3 <> '0'
 	THEN
 		v_add_clause := v_add_clause||CHR(10)||' AND '||p_column3||' = '''||UPPER(p_value3)||'''';
	END IF;
 	IF	p_column4 <> '0'
 	THEN
 		v_add_clause := v_add_clause||CHR(10)||' AND '||p_column4||' = '''||UPPER(p_value4)||'''';
	END IF;
  	IF	p_date_column <> '0'
  	THEN
  		v_add_clause := v_add_clause||CHR(10)||' AND '||p_date_column
  				||' BETWEEN '||''''||UPPER(p_date1)||''''||' AND '||''''||UPPER(p_date1)||'''';
	END IF;
	v_stmt:=
	'INSERT INTO icis_pipeline
	 SELECT icis_facility_frs.icis_facility_id
		,icis_facility_frs.primary_name
		,icis_facility_frs.location_address
		,icis_facility_frs.city_name
		,icis_facility_frs.state_code
		,icis_facility_frs.pgm_sys_id
		,v_pipeline.act_seg,
		v_pipeline.statute_code||icis_facility_pgm.pgm_sys_id||decode(
			      v_pipeline.act_seg,0,v_pipeline.activity_id,v_pipeline.act_seg) segment
		,icis_data.get_min_pipeline_start_date(v_pipeline.statute_code,
		v_pipeline.act_seg,v_pipeline.activity_id) min_start_date
		,icis_data.get_max_pipeline_close_date(v_pipeline.activity_id) max_pipeline_close_date
		,v_pipeline.region_code
		,v_pipeline.statute_code
		,v_pipeline.actual_begin_date
		,v_pipeline.activity_type_code
		,v_pipeline.actual_end_date
		,icis_data.get_pipeline_actual_date(v_pipeline.activity_id,''INFRR'') infrr
		,icis_data.get_pipeline_actual_date(v_pipeline.activity_id,''INSRC'') insrc
		,icis_data.get_cmd_date(v_pipeline.activity_id) cmd_date
		,icis_data.get_sfd_date(v_pipeline.activity_id) Disclosed_date
		,icis_data.get_case_screen_date(v_pipeline.activity_id) case_screening_date
		,DECODE(v_pipeline.activity_type_code, ''AIF'', xref_enf_type.enf_type_code,NULL) enf_type_code
		,icis_data.get_court_enf_nmbr(v_pipeline.activity_id) court_enf_nmbr
		,DECODE(v_pipeline.activity_type_code,''JDC'',
			icis_data.get_actual_date(v_pipeline.activity_id,''DOJ'')
			,icis_data.get_actual_date(v_pipeline.activity_id,''CPOA'')) ea_issued_date
		,DECODE(v_pipeline.activity_type_code,''AFR'',
			icis_data.get_actual_date(v_pipeline.activity_id,''CAFO'')
			,icis_data.get_actual_date(v_pipeline.activity_id,''FOE'')) ea_concluded_date
		,icis_data.get_sum_penalty_required_amt(v_pipeline.activity_id,
				v_pipeline.statute_code,icis_facility_pgm.icis_facility_id) sum_penalty_required_amt
				icis_data.get_pipeline_flag(v_pipeline.activity_id,
				v_pipeline.icis_facility_id,v_pipeline.statute_code,''SEP_ID'')
				,''JDC'', icis_data.get_pipeline_flag(v_pipeline.activity_id,
				,NULL) sep_flag
				v_pipeline.icis_facility_id,v_pipeline.statute_code,''COMP_ACTION_ID''),
				,NULL) comp_action_flag
				v_pipeline.icis_facility_id,v_pipeline.statute_code,''POLLUTANT_CODE'')
				,''JDC'',icis_data.get_pipeline_flag(v_pipeline.activity_id,
				,NULL) pollutant_code_flag
		FROM icis_facility icis_facility_frs
		,icis_facility icis_facility_pgm
		,xref_enf_type
		,v_pipeline
		WHERE v_pipeline.icis_facility_id = icis_facility_pgm.icis_facility_id
		AND  ((( icis_facility_pgm.facility_uin =icis_facility_frs.facility_uin
			AND  icis_facility_frs.pgm_sys_acrnm = ''FRS'' )
		OR  (  icis_facility_pgm.icis_facility_id = icis_facility_frs.icis_facility_id
		AND  icis_facility_pgm.facility_uin IS NULL
		AND  icis_facility_pgm.pgm_sys_acrnm = ''ICIS'')))
		AND v_pipeline.activity_id = xref_enf_type.activity_id (+)';
	v_stmt:= v_stmt||CHR(10)||v_add_clause;
	COMMIT;
	EXECUTE IMMEDIATE v_stmt;
 	THEN
 		v_stmt := 'DELETE FROM icis_pipeline '||
 			  'WHERE '||p_date_column||' < '''||p_date1||
 			  ''' OR '||p_date_column||' > '''||p_date2||
 			  ''' OR '||p_date_column||' IS NULL';
	END IF;
 	DECLARE
 		CURSOR 	cur_find_act_seg IS
		SELECT	DISTINCT act_seg
		FROM	icis_pipeline
		WHERE	activity_type_code = 'CMD'
		AND	statute_code IS NULL
		AND	act_seg <> 0;
	BEGIN
		FOR 	rec_find_act_seg IN cur_find_act_seg
		LOOP
		DECLARE
			CURSOR 	cur_find_cmd IS
			SELECT	*
			FROM	icis_pipeline
			WHERE	act_seg = rec_find_act_seg.act_seg
			AND	activity_type_code = 'CMD';
		BEGIN
			FOR 	rec_find_cmd IN cur_find_cmd
			LOOP
			DECLARE
				CURSOR 	cur_fill_statute IS
				SELECT 	statute_code
				FROM 	icis_pipeline
				WHERE	act_seg = rec_find_cmd.act_seg
				AND	activity_type_code <> 'CMD';
				v_count	NUMBER := 0;
			BEGIN
				FOR	rec_fill_statute IN cur_fill_statute
				LOOP
				IF	v_count = 0
				THEN
					UPDATE 	icis_pipeline
					SET	statute_code = rec_fill_statute.statute_code
					WHERE	icis_facility_id = rec_find_cmd.icis_facility_id
					AND	act_seg = rec_find_cmd.act_seg
					AND	activity_id = rec_find_cmd.activity_id;
					v_count := 1;
				ELSE
					SELECT 	icis_facility_id
						,primary_name
						,location_address
						,city_name
						,state_code
						,pgm_sys_id
						,act_seg
						,segment
						,min_start_date
						,max_pipeline_close_date
						,region_code
						,activity_id
						,rec_fill_statute.statute_code
						,actual_begin_date
						,activity_type_code
						,actual_end_date
						,infrr
						,insrc
						,cmd_date
						,disclosed_date
						,case_screening_date
						,enf_type_code
						,court_enf_nmbr
						,ea_issued_date
						,ea_concluded_date
						,sum_penalty_required_amt
						,sep_flag
						,comp_action_flag
						,pollutant_code_flag
					FROM	icis_pipeline
					AND	rownum < 2;
				END IF;
				END LOOP;
			END;
			END LOOP;
		END;
		END LOOP;
	END;
     	OPEN 	pipeline_report_rc FOR
     	SELECT 	*
	FROM	icis_pipeline
	ORDER	BY act_seg;
END;
You cannot commit in free hand SQL.
You cannot update in free hand SQL.
You cannot insert in free hand SQL.
My DBA was able to figure out the problem, thanks for your help.
Could you explain us, please?
Here is the actual sql I was using to call the procedure so we were not commiting/updating/inserting via free hand, but through the procedure.
begin
insert_icis_pipeline (:cbo, NULL,NULL,‘icis_facility_frs.pgm_sys_id’,‘110010781092’,‘v_pipeline.region_code’,‘08’,NULL,NULL,NULL,NULL,NULL);
end;
Since we have to use the ‘on commit preserve rows’ feature to get data returned, we didnt realize we also needed to truncate the table before we ran the procedure again. He included the trunc and it is now working.
It wasn’t so easy!!
Good! :wink:
