monthly hot fix
hi this is krishna some one tell me what is the procedure for instaling the MHF1 in the XIR2 environment and what are the specifications that should be needed to install it in the machine.
thanks in advance
kirity (BOB member since 2006-05-29)
hi krishna,
I have installed the MHF1 recently, before you install MHF1 you must install the service pack SP1 and then MHF1.
Only thing you require is 2-3 gb space on your HDD :slight_smile:
i hope this will help.
Amit
amit.khadilkar (BOB member since 2005-11-11)
thanks i will try it
