Can you please let me know How to get the difference between months in given date range.
Eg:
01-01-2007 to 31-12-2007 = 12 months
OSR
osr (BOB member since 2005-07-06)
Eg:
OSR
You can find the month differnce either by using SQl or you can make use of Custom function here. In the case of SQl you can write direct function MONTHS_BETWEEN, and if you want to write custom function Then you can write the function as shown below:
$DATE1 = TO_DATE(‘01-JAN-2008’,‘DD-MON-YYYY’);
$DATE2 = TO_DATE(‘22-JAN-2009’,‘DD-MON-YYYY’);
$MM_DIFF = TO_CHAR($DATE2,‘MM’) + (12 - TO_CHAR($DATE1,‘MM’));
$YY_DIFF = TO_CHAR($DATE2,‘YYYY’) - TO_CHAR($DATE1,‘YYYY’)-1;
$FINAL_MM = ($YY_DIFF *12) + $MM_DIFF ;
PRINT($FINAL_MM);
PRINT($MM_DIFF);
PRINT($YY_DIFF);
I think This will solve your problem.
-Sunil Lakhani
Sunil Lakhani (BOB member since 2009-01-19)
sorry i missed one statement in the previous coding for custom function i.e. return statement
Please review the code again as shown below
Return ($FINAL_MM);
In 12.0 the date_diff supports months as well.
date_diff($date1, $date2, ‘MM’)
Werner Daehn (BOB member since 2004-12-17)
