Modify Crystal Reports in BO XI 3.1 Infoview
Hey,
i checked the forum but i couldnt find a answer for my Question. Is it possible to modify Crystal Reports in the Infoview?? Something like the interactive mode for Webi. I heard something from a Crystal Reports Explorer but there is nothing like this in my in Infoview. I just can open the Crystal Report with the Crystal Viewer.
Maybe someone can help me
Jooken
jooken :austria: (BOB member since 2009-02-20)
There is no CR explorer in XI3.1. It exists in XIr2 although I have not used it to modify a report. I think you can only create not modify using CR explorer. In XI3.1, you can only modify any Crystal Reports using the CR client.
AnthonyJ :philippines: (BOB member since 2006-06-30)
So i can just use the infoview to share the reports and if i wanna modify them i have to install CR client on the hosts?? But then i dont know what the Crystal Report Server ist for???
Yes, you use Infoview to collaborate, share, schedule, etc. any crystal reports, webintelligence reports and building dashboards using a thin client. Use CR client to modify Crystal Reports. CRS is used for server/user administration.
You can install the CR client locally in your machine and/or in the server.
Anthony and All,
Can you format CR in Report Viewer?
By format means removing column, changing font colors, turning table into charts etc…
Thanks!
bg
bennygene (BOB member since 2005-04-14)
