Missing groups listing for publishing documents
Greetings all. I hope someone can help me with our problem. Whenever you are publishing a document to the repository from Business Objects, you are supposed to be given a list of groups that have been set up within Supervisor. This list of groups is supposed to appear in the Send To box.
Please correct me if I’m wrong…but shouldn’t at least the organization group be listed?
Unless you have an incorrect supervisor setting, if you know that you SHOULD be able to publish as the account you are using then, guessing that you are using Version 5 or 5.01 then it is a bug that is fixed in 5.0.2. Doesn’t happen to every user either, it partly seems to depend on how many groups you are in and in what order they are listed. Definately fixed in 5.0.2 though :slight_smile:
Jonathan
Project Leader
Group Medical, Regulatory and Product Strategy IS.
