Question:
After submitting a report I see only 1 row of the data rows returned in the report, but I do see all of the rows when I view the Data Results. How can I see all of the data on the report? Denise DuPont
What you need to do is format your report to avoid duplicate row aggregation. Go to Format -> Table from the menu bar. On the General tab, there is a check box option to Avoide duplicate row aggregation. Select it. This should show all your rows of data.
Seth Cohen
Systems Engineer
Profound Solutions
317.579.5100/1.800.411.2755
fax: 317.579.6279
