Missing Auditor Reports.....
Hello all,
Our free auditor reports that come along with the software are missing.
An error has occurred: Cannot open report document. — File Repository Server error : File frs://Input/a_096/026/000/6752/~ce16704c7435841d49.rpt not found on File Repository Server
It is an old installation done by a consultant more than 2 years ago.
Question: Where can I find these reports?
If I find them, I will create appropiate folders in the I/P FRS and put them in there one at a time.
Thanks in advance,
Diamond :india: (BOB member since 2009-08-26)
Do you have BO installations? If yes then check the content of the M29.cab file.
Yes, I found the M29.cab file, ~47 MB size. Now, what do I do with it?
Open it - Windows Explorer should be able to open the file without a problem - and extract file(s) that you need.
The .cab file contains BIAR files with audit reports and universes for various databases and languages. So extract only those BIAR files that you need. Then use Import Wizard to import the content of the BIAR file into your BOE.
Yes, thank you !!! I was able to retreive all the reports
