Minuts to HH:MM format
Hello Experts,
Please suggest how to change the number of minutes into HH:MM format like suppose I have minutes count 130 then I want to display it in 02:10.
Please assist.
vijesh.chandra :india: (BOB member since 2009-05-29)
Divide the 130 by 60 for hours. 130 Mod 60 will give you the minutes.
P.S: Please refrain from using ASAP, urgent, etc,… This is a voluntary forum. For urgent issues, contact technical support. Please edit your post and remove asap from the post.
Hi Vijesh,
The formula for converting the number of seconds into HH:MM:SS format is described here:
You need to tweak that formula slightly because you have minutes, not seconds.
Thanks Jansi.
It worked for me :smiley:
