hi
Iwant to convert a number (Minutes) into HH:MM:SS (00:00:00) format could any one help me with this … as i searched i the web i got the converstion from seconds… how could i do with Min please
chinny (BOB member since 2014-06-04)
hi
Welcome to B B!
What version/tool are you using? e.g Webi 4.1 SP2, Deski 3.1
its webi 4.1
OK, so we need to get a moderator to move this post to the Webi forum first then.
What’s your starting point and we can get to the end point from there.
Done 8)
so where i need to check my reply for this now please ? i m new here
Right here, in this topic, nowhere else
So, now we’re in the right forum (thanks Marek), what are you starting from? Do you have a numeric object in minutes that you want to convert to hours and minutes?
Yes I got a numeric object displaying in min ( eg: 39,456 ) I want end result iin hh:mm:ss format
thanks in advance
I assume from your example that it will always be whole minutes?
In which case you would need:
=FormatNumber(Floor([WholeMinutes]/60);"00")+":"+FormatNumber(Mod([WholeMinutes];60);"00")+":00"
Where WholeMinutes is the object that contains the number of minutes that you want to parse out.
So 39,456 would become 657:36:00
Is that what you’re after?
thanks its working
