migration/upgradation of a universe from test to production
I have a universe (x1) in the production repository and i made upgradation of the universe in the test repository. This universe is saved in the test repository in the same name. i have 100 reports running in the production based on the x1 universe in the production. Now i would like to replace the old x1 univese with the upgraded x1 universe from the test with the same name. How could i do that? I would like to do it such a way that after exporting the upgraded universe from test to production all the reports should be able to pint that upgraded universe.
-----Chan
chan2005 (BOB member since 2005-05-29)
If you are wanting to migrate a universe from one repository to another the Designer Forum FAQs have the steps listed:
Here
Michele Pinti (BOB member since 2002-06-17)
Your best bet would be the overwriting of the exisisting prod repository universe with the test repository following the steps needed, for migration across repositories.
General supervisor could do that overwriting.
Manasi (BOB member since 2004-12-17)
That seems like a bit of overkill just to migrate one changed universe. I think Michele’s suggestion is the way to go.
