Migration issues from BOXI 2 to BOXI 3 R2
We are testing the migration from BOXI2 to BOXI3. I have come across some DESKI reports where once I set the prompts and refresh in Infoview, it fails with “SetPrompts failed” message. I have tried the following:
  1. Recreate prompts,
  2. Import/Export reprot after purging the DP
Has anyone had the same issue? If so is there a fix for this?
yashob :cuss:
yashob (BOB member since 2009-04-07)
Please look at this topic…
http://forumtopics.org/busobj/viewtopic.php?p=652191&sid=3c5b5bd263d9ea3ca112c29c37fd0754
monty4u :us: (BOB member since 2006-12-12)
Hi Yashob,
Perhaps, did you find a solution for this issue?
Thanks…
JohnJustus :us: (BOB member since 2007-06-25)
