Migration from Test to Production Env
If we migrate our ATL to Production environment then we have to create the same target into the target database of production … is it?
(provided if table doesn’t exist in PROD_TRGT_Database)
other way around, can we use template table to create table in Production target database and later we can import it.
your suggestions please!!
sjain :india: (BOB member since 2009-04-17)
In theory yes, but I wouldn’t do that. You migrate the ATL to prod and in parallel you migrate the sql script that changes the target tables.
