system
April 23, 2007, 2:07pm
1
Is there a way to use Microsoft Task Scheduler using -user xxx -pass yyy -blind as was the case in versions 5 and 6?
If I remove the -blind the task starts but I’m prompted for the password.
As anyone used the “Microsoft Task Scheduler” with XI R2 Desktop Intelligence?
Mike V (BOB member since 2002-08-15)
system
April 24, 2007, 5:09am
2
Yes I have used XI R2 Deski report to open from a batch file having user xxx -pass yyy -blind and scheduled the same in Windows scheduler.
hyder
haider (BOB member since 2005-07-18)
system
April 24, 2007, 6:45pm
3
Hi Hyder
Just can’t get it to work with DeskI using W2k. Same bat works fine with 6.1.
Here is what I’m using in to run: C:\PROGRA~1\BUSINE~1\BUSINE~1.5\WIN32_~1\busobj.exe “D:\XI Docs\GSC NOI 2007 XI.rep” -user xxx -pass yyy -blind
system
April 25, 2007, 10:33am
4
try this:
“C:\PROGRA~1\BUSINE~1\BUSINE~1.5\WIN32_~1\busobj.exe” -user “xxx” -pass “yyy” “D:\XI Docs\GSC NOI 2007 XI.rep” -nologo -blind
system
April 25, 2007, 12:32pm
5
Thanks for the reply, haider.
I tried what you suggest with no avail. Looking at theTask Manager bus.exe runs for a few seconds then dies. It simply refuses to start using -blind. Removing -blind I’m prompted with the “User Identification” screen with System, User Name and Authentication already filled out.
I wonder if other parameters are needed? I tried this on 3 different machines with the same results.
