Hi gurus,
I am tasked to setup Metapedia dictionary for a specific department. I am aware of the technicality of the tool but not sure where to start on capturing terms.
Now the department already has reports built, what would be a good strategy to:
- create a strucutre in Excel to start capturing data terms and description?
- should the terms come from the WebI dimension and measure?
- how do you handle when the same field is used in multiple departments since Metapedia does not allow the same term name?
- How should the Categories be defined to organize the terms? Should the Universe classes become categories and sub categories?
Thank you.
P34C3 (BOB member since 2005-11-30)
