I have 2 cross tabs as in attached excel. I need to merge the two cross tab reports based on the common Dimension column such that drilling can be done on the dimension and it is effective on both the Cross Tabs (Measure1, Measure2 and Measure3).
Filter1 defined in the Universe which has a Prompt on “Month Name”. Based on the Prompt value, it returns the Month, Month-1 and Month-2. (Past 3 Months including Selected Month)
Filter2 defined in the Universe which has a Prompt on “Month Name”. Based on the Prompt value, it returns the Month
The 1st CrossTab has
Dimension+ Measure1+Measure2
displayed for 3 months by using the Filter as defined above.(Month,Month-1,Month-2) -
The CrossTab 2 has
Dimension+Measure3 only for 1 month selected by the user(Month)
Qs. How do we merge Cross Tab 2 with Cross Tab 1?
Report.xls (29.0 KB)
Pooja.29.84 (BOB member since 2010-04-28)
